Thread: problem solved
    Dec 2008
    12
    Default problem solved
    I had posted about a problem with my hot water base board banging(water hammer) when the zone shut off. the problem was the new honeywell zone valve that the oil company service put in.
    after 3 house calls for the same problem their lead tech was sent and removed a spring on the valve that assists closing the valve. he said they have received many complaints of this and honeywell said they had changed this spring to a heavier spring. spring is not needed and now I can sleep. hope this helps others if needed and thanks to the people who replied
    1,131
    Default Re: problem solved
    Good to hear you got the problem resolved....and thanks for checking back in. Not too many folks bother to do that.
    731
    It is nice to hear that the problem you posted about on this string:
    http://advice.thisoldhouse.com/showthread.php?t=9990
    has been resolved.
    You can find your old posts and topic strings by using the drop down menu to navigate to your profile, and from there view your statistics tab; or from any post you have participated in you can click on your display name, and from that drop down menu display a list of all posts you have made previously OR all topic strings you created.
