    Jan 2009
    Default floor insulation
    I'm going to insulate between floor joist with fiberglass batts
    do I use "faced or unfaced" cover with vapor barrier? if using faced which side is against floor?
    Jan 2009
    Buffalo
    Default Re: floor insulation
    Vapor Barrier goes to the warm side usually...
    54
    Quote Originally Posted by harrison View Post
    Some questions need to be answered first. Where is the floor and what is under it? Where do you live? Vapor barrier placement depends on whether you live in a hot or cold climate.
