    Worthington OH
    0
    Default ceramic tile underlayment requirements?
    My kitchen/dining/utility rooms have two layers of 3/4" plywood.
    I would like to remove one of the layers of plywood and replace it with 1/4" cement board before installing ceramic tile.
    Would this be an acceptable amount of underlayment?
    Or should I use Ditra (which I would prefer not to use only because of the really high cost).
    A little more info...I want to remove one layer of the plywood because this would allow me to have a smooth transition between the new ceramic tile and the adjacent hardwood floor. Currently there are two layers of 3/4" plywood and one layer of vinyl on top of that (which is a smooth transition to the hardwood). My joist spacing is 16" on center, joists are 2x10, and 16 feet long.
    612
    Default Re: ceramic tile underlayment requirements?
    If you go to www.johnbridge.com they have a deflection calculator that you can use to see how "bouncy" your floors are and see if anything needs to be done before installing the tile.
    Worthington OH
    0
    didn't see the deflection calculator anywhere on that site
    Worthington OH
    0
    how much of a difference would it make to use the 1/2" cement board rather than the 1/4" cement board
    612
    http://www.johnbridge.com/vbulletin/deflecto.pl
    Here is the link to the deflection calculator. I don't think cement board adds any stiffness to a floor so 1/2" vs. 1/4" won't do anything structural for you. A 3/4" subfloor is a minimum thickness in my opinion. Read through the johnbridge forums for all the answers you could ever want about tile jobs.
    Jan 2009
    Buffalo, NY
    34
    That calculator is great, thanks guys.
