    Dec 2008
    Default ducting heat from a fire place
    I will be replacing a fire place the new one has 2 8 inch heat duct I would like to duct it into the force air system
    5,825
    Default Re: ducting heat from a fire place
    If you run it to the cold air return you can use the furnace blower to distribute the heat.
    Sand Springs, OK
    467
    I would caution you to care for the chimney and those vents very carefully. The house across the street burned down because of a failure in the joints around the same kind of set up. The owner cleaned the chimney but he didn't get those vents.
    Debby in Oklahoma
