    Nov 2008
    14
    Default bath tub drain conundrum
    HELP!!!!!
    The drain in my Kohler - jet tub is destroyed. My very "handy-man" husband agreed to replace it until he took one look and found there are no cross bars to attach a tool to. They are corroded away.
    The conundrum is : how to get the old drain out to replace it?? Please help! Advise?
    Very gratefully yours
    John F's wife
    Nashville, TN
    148
    Default Re: bath tub drain conundrum
    This is where you find out how good your husband is with a sawsall or recripricating saw. He will have to cut off the old drain WITHOUT cutting into the fibergalss of the tub. It will be just like cutting off a nut from a rusty bolt that is stripped.
    Process of elimination. Good luck.
    Oct 2010
    7
    There is a tool for that. It is used with a socket wrench.
    6,097
    First be sure the drain isn't installed with a nut on the under side. Not all are screwed in from the top.
