    Default Fireplace Conversion
    I would like to replace the stone around this fireplace with a different type and color of stone and also convert it into a gas fireplace.
    Could someone please enlighten me on what it would take to accomplish this???
    Thanks
    Sara
    Denver and Dublin
    63
    Default Re: Fireplace Conversion
    Judging by the style, depth of the hearth and mantle and the stone style, this was fairly recently (5-10 years ago) covered with a stone veneer and was a brick hearth and mantle originally. Your home looks like 1910-20 Craftsman and you fireplace certainly is not that.
    The upright section and hearth area was probably mortared directly to existing brick. That will make it a bit of a chore as, being fairly new; it will be solid and difficult to remove. The bright side is that anyone who would have done that job probably wasnít too experienced and the mortar is probably weak and should break apart easily.
    Once you have an even surface after removing the stone, you can cover the base brick with what you like. I doubt that the brick below will be salvageable.
    Obviously, since Iíd never recommend a homeowner do their own gas work, you should be able to find a professional to convert the opening to gas fairly easily if you have gas available on your property.
    If I only knew what I was doing!
    Thanks Kelly,
    I didn't realize that the fireplace is not original to the house.
    I'm posting a pic of the exterior, the home was built in 1922. The next question I have is - does the stonework on the front porch column also look like a veneer?
    We just bought this house, the home inspector advised is that the stone work needs shoring because its crumbling.
    The addition at the back also needs to be beefed up because its not well supported!!
    I wanted to have the same support colums at the back to look like the columns in the front just to unify the look of the back and the front.
ID:	1936   Click image for larger version.
    Denver and Dublin
    63
    Well, the fireplace is original, the veneer isnít. Just to clarify.
    The stonework in front is not original, although the taper to the columns is. Itís probably a decorative veneer over the original tapered columns. Most people simply veneer those tapered areas with architectural shingles. The original shingle cover tends to be worn by wet weather, vine growth or simple sprinkler erosion and, well, normal rot because of the growth and wet around them.. The stone veneer certainly hasnít anything to do with anything structural. The columns themselves, however, are structural supports to the roof above them and usually rest on, relatively, shallow concrete caissons.
    Your second floor on the back is very unlikely original. And, as can be expected, inspectors tend to be concerned about the original foundationís capability to support the addition. Making a guess, based on the lap siding surrounding it, the addition was likely added in the late 60s or early 70s. The extension to the back, as you probably are aware, also isnít original. But you certainly can use tapered supporting columns beneath it to enhance the look and make inspectors happy.
    AsideÖ All in all, it seriously helps to know where the houses are when I answer questions. Building codes are ďUniformĒ but building needs and inspector expectations vary widely by region. Other than the lush growth, Iíd pick that house as a Denver 1920s. The new Mini-Mansions around it pinpoint a few possible locationsÖ But, if you donít mind my asking, and for my general info-banks, where is that house located?
    My apologies for not providing complete info, the house is located in Vancouver, British Columbia.
