Results 1 to 9 of 9
    Dec 2008
    Default Jammed Whole House Water Filter Housing
    I have a whole house water filter problem: every time I need to change the filter element I can't get the canister turned out of the top housing. I've broken 2 of the plastic wrenches, tried using 2 strap wrenches together and even made my own "wrench using wood and nylon rope. I contacted the manufacturer who recommended using food grade silicon grease on the threads and the O ring seal. I did that and was careful not to over tighten. It's time to change the filter and once again the canister housing the filter cartridge is jammed. Iím stumped and frustrated. Any ideas short of replacing the whole unit? I'm not adverse to that option, but donít want to end up with the same problem?
    Denver and Dublin
    63
    Default Re: Jammed Whole House Water Filter Housing
    This is one of those questions, at least in my experience, that there is no easy answer to. I've dealt with those systems in residential and commercial applications and the best thing I can tell you is "finesse".
    They're most often made of fiberglass or plastic. When you put a pipe wrench on them it compresses opposite sides, and when you apply pressure it's like applying breaks to a peddle, it clamps down, compresses the plastic and it won't budge because fiberglass or plastic has it own surface resistance that you tend to be increasing.
    I've applied grease to them, graphite, and WD40, and they all tend to make the situation worse because they only seem to enable the option to compress and bind.
    This isn't a great answer but it works for me. The old Amish "Gentle Persuasion". Grip it with your hand or a strap wrench very evenly all around and tap it lightly with a screwdriver or small hammer and turn gently. It's like the old Arthur and Excalibur story. Every knight in the realm tried to brute force the sword from the stone, Arthur just coaxed it because he didn't know any better.
    The restrictions on sanitation prevent the device from being anything but something which works out to be pliable. A pliable cap doesn't work like we expect it to but it does work.
    If I only knew what I was doing!
    1,131
    Bob,
    You are using the pressure relief valve on top of the fixture before trying to unscrew the canister........yes?
    If you don't, then you're fighting against X pounds of water pressure per sq. inch.
    731
    couldn't you just close supply valve and open some faucets or valves downstream to drain the water & pressure from the filtration unit before you began, instead of just closing valves before and aft and leaving the device under pressure?
    1,967
    Quote Originally Posted by ****hiller View Post
    Bob,
    Ditto that, makes all the difference.
    Hand tighten, then use the wrench only to stop any leaks.
    Dec 2008
    Richmond, VA
    15
    I hear you. I actually replaced mine with a large capacity filter and took the time to build in a bypass and pressure relief valve and tubing. Best idea every. I put ball valves before and after the filter. That way, I could totally isolate it. I than added another ball valve with a drain tube. I put a bucket under the drain tube and then released using my ball valve and drain tube. No mess. It was much better then using the crummy pressure relief button. Adding the bypass meant that I could rinse the muck out of the bottom of the canister even when the whole house filter shut off. The unfiltered bypass was an outside spigot, so being filtered wasn't an issue.
    Also, the amount of force should be quite a bit lighter than one would think. It's like a spin-on oil filter; just enough to make it water tight.
    1,862
    Had the same problem with my Grandma's water filter. Yes, I was relieving the pressure. I ended up using faucet grease on the threads and o-ring; that helped quite a bit. I find that even still it doesn't come off easily; but rather than trying to force it off, I use even, steady pressure and it eventually comes loose.
    Aug 2013
    Quote Originally Posted by KKelly View Post
    Keyword is "finesse"... I've never looked forward to this household chore... Finesse is the keyword here, and also a little patience. In addtion to finesse, you'll need a 32oz deadweight mallet and the black plastic wrench with the nubs that fit onto the blue body...
    Draw a black line with a Sharpie on the blue body - visually aligned with some reference point on the black housing. Using the black plastic wrench, wale on the wrench with the mallet as close as possible to the stronger part of the wrench...
    Key: Don't expect it to loosen all at once. Inspect that black line you drew on the blue body, and sure enough you'll see that you are making progress in very small increments. Once you see you've rotated a degree or two, you'll actually be convinced that it's starting to loosen. You're home free...
    Also, lacking any handy plumbers grease, I used ordinary vasoline on the threads of the blue body. I think that helps, or else it's a placebo.
    7,633
    This is an old post, but the problem is not.
    This is how I do it: First I shut the water supply, disconnect the water supply into the unit and out from the unit, take the unit outside the house and start working on it.
    I use 2 wide wrenches. One to hold the body as a vise (I don't use the plastic holder that came with the unit - it's too weak). The other to turn the top of the filter unit.
    When you are ready to put the top part, lubricate the thread with Vasaline/petroleum jelly, as suggested above, not WD40. Hand tight + 1/2 a turn with the wrench. Assemble the supply lines. Check for leaks.
