Thread: no drainage
    Dec 2008
    Default no drainage
    is it possible for mud to cover the pea gravel so it would not drain into the sub pump.?
    thank you.james
    Denver and Dublin
    63
    Default Re: no drainage
    Yes, but it's more likely the mud will clog your pump before it ever stops the drainage to it.
    There are many types of "sub" and "sump" pumps but they all require a higher volume of fluid to debris to remain operable.
    If I only knew what I was doing!
    731
    Is it possible for clay, mud, silt, to clog up a drainage system? you betcha! Is it possible to cap off a pea gravel area with clay/mud and prevent perking to the earth below, or make the area less permable? Yes Siree!
    Its also possible for drain tile to collapse/break.
    So yes, James it is possible your drainage system is choked and it could very well be preventing drainage to your sump pit.
