    Dec 2008
    Default No Drainage
    we have always had water coming in sub pump after heavy rain,but now there is none coming in,we had plumbers inspect clay pipes with cameras
    and they said they where like new,we had over 2 inches of rain the other day and none came in.please help.
    thank you.james
    731
    Default Re: Drainage Problem
    Quote Originally Posted by catfish46 View Post
    thank you.james
    You titled your post Drainage Problem. So far you haven't described anything that indicates a problem of any kind.
    Dec 2008
    thanks for your time,but even the plumber found it odd that there was no water in the pipes after this downpour and said that mud may have clogged the pea gravel up,is this possible.
    731
    yes it is possible for expansive soil, clay, silt, "mud" etc. to choke a drainage system.
    London
    9
    larger gutter may be needed or additional down spouts may need to be installed.
    After the gutter issues has been taken care of, pipe out the down spouts by installing at least a 4 inch solid drain pipe to the street or the back corner of the backyard. If you are connecting more than one down spout to a drain pipe, a large pipe may be needed.
