    Default dishwater in the dishwasher
    Our dishwasher runs and drains fine, but if we don't use it frequently, foul smelling water starts to pool at the bottom. It must be coming from the sink. Any ideas?
    Coventry, RI
    340
    Default Re: dishwater in the dishwasher
    Make sure that the hose coming from the dishwasher to the sink drain has a high point somewhere that is as high as the bottom of the counter. This will ensure that any water draining from the sink is not forced into the dishwasher.
    Mike
    The drain hose (which is connected to the garbage disposal) doesn't reach the counter. It pretty much drops from the disposal to the drain hose. Could the disposal water be leaking down into it?
    South*East
    1,210
    Quote Originally Posted by ptdodge View Post
    That's what is happening. Mike gave you the solution.
    John
    Agree with what had been posted.
    Water flows down hill --- the reason the dishwasher drain hose should be at the underside of the counter is it's higher than the drain line or disposal to prevent back flow such as you have.
