    Default Replace of Bathtub Faucets
    How do I replace / change the "bathtub faucets" in a trailer?
    Nashville, TN
    149
    Default Re: Replace of Bathtub Faucets
    What is on the other side of the bathtub faucet? Is it an outside wall or is it a closet?
    If it is a closet, cut a hole in the wall, disconnect the old faucet and replace with a new one. Then you will be able to make an access panel cover for the hole you just cut.
    Now if it is an outside wall, well...
    Process of elimination. Good luck.
