    Smile Grounding a television antenna to gas line?
    Think about it? Does this make any sense? I just watched a segment moments ago (July 14, 2010) where an installer showed Kevin O'Connor how to attach a lighting strike ground from the HD antenna mounted to the chimney flue down to the homeowner's gas line at the meter. Perhaps Tommy and Wild-E-Coyote should be called in to build a shed around the meter so a few powder kegs could also be stored- now that would ensure complete annihilation!
    A word to the wise- seek out the water supply line or stake a rod into the ground (away from the gas supply).
    8,002
    Default Re: Grounding a television antenna to gas line?
    We had this discussion when it first aired last year. The general consensus was that the installer was a putz.
    The deep South
    459
    Wouldn't do any good around here . Once you get past the meter , the line is poly .
