    Unhappy condensating vents
    When trying to keep the condensation out of the basement ductwork from sweating vents,and using a dehumidifier, should we keep the windows closed? It is part cellar and part crawl space. I can`t decide if we need the windows open a little for air flow or closed from the humidity?
    Jul 2009
    Northeast
    661
    Default Re: condensating vents
    I would think if your trying to dehumidify a space you would keep the windows closed otherwise your letting in more humid air
    Quote Originally Posted by Sten View Post
    ... or trying to dehumidify the whole country
    Wink Re: condensating vents
    Yes, I know your right! As soon as I tried it and opened a window, it was condensating way worse!!!! Thanks for responding!
    Nov 2011
    Charlotte, NC
    12
    problem is, you can close the windows but if it's a vented crawlspace you're still pulling in moisture from outside.
    The Ghetto way to do it would be to ensure you have a great poly coverage on the ground in the crawlspace (assuming it's not concrete) and plug the vents with thermax.
    Or, get your state code and a quality contractor in your area to do it!
    Helping Homeowners understand the Typical Causes and Solutions to Hidden Content issues!
