    Cincinnati, Ohio
    Cool flooring or cabinets first?
    I couldn't find this in an article on TOH. If it's already been discussed here, please direct me to the thread. Both the flooring and cabinets will be cheap, but the cabinets will cost more.
    Deb in Cincy
    Mar 2010
    Canada
    86
    Default Re: flooring or cabinets first?
    I would recommend laying the flooring before installing the cabinets. It will be much easier than trying to work around the base cabinets. When it comes time to install the base cabinets they will be all on the same surface plane and makes a cleaner look, in my opinion.
    You need to lay the finsh flooring in areas where the stove , fridge and built in dishwasher will be located anyway, so you might as well do the whole area.
    Also, if you decide to do remodeling down the road it will far easier than trying to patch in the flooring.
    Cincinnati, Ohio
    Thumbs up Re: flooring or cabinets first?
    Thx, Leonard Homes.
    Deb in Cincy
    6,075
    It will depend on the type of flooring you are installing. If you are installing a laminate floating floor you do not want it under the cabinets. Instead you would use plywood the same thickness as the flooring as a spacer under the cabinets. If you are installing hardwood flooring or vinyl flooring install the flooring first.
    Cincinnati, Ohio
    Talking Re: flooring or cabinets first?
    thx, Jack. probably sheet vinyl.
    Deb in Cincy
    6,075
    Be sure to have some heavy cardboard or a piece of plywood to lay on the floor to protect it when working with the cabinets and always lift and set them into place rather than sliding them.
    Sort of --- you can install cabinets over some name brand laminate floors as long as there is no fastening of the cabinets to the floor required or a maximum of 250 lbs isn't exceeded. --- not that I would put laminate floors down anyway.
