Results 1 to 10 of 11
    145
    Default toilet leak at tank
    Can some one tell me where the problem is. My toilet leaks at the tank only when it is flushed. If it is not being used ,it doesn t leak at all. All is dry.
    Thanks again
    6,080
    Default Re: toilet leak at tank
    Could be the seal between the tank and the stool or the small line on the fill-valve that goes to the overflow may have come loose and is spraying the lid and running down the back.
    South*East
    1,257
    You need to replace the tank to bowl gasket. At the same time I would also replace the tank bolts, nuts & washers. You can get a kit at the big box stores.
    John
    Texas
    128
    Let's go back to JLMcDaniels reply. Remove the tank top and make sure the line to the overflow has not come loose. Fixing this takes only 5 minutes and costs nothing. Only after eliminating this would I start checking the seal at the bottom of the tank.
    Before removing the tank, turn off the water and hold the flush valve open. Then, take a wet vac and remove the rest of the water. Really saves on clean-up and mopping.
    Feb 2011
    Hi l.bro,
    I have the same problem. I called plumber and he changes the valve. Try follow instructions you get from other members. Hope it will fix your tank leakage.
    Feb 2011
    I also have the same problem.
    vinyl windows richmond
    Feb 2011
    9
    The leaked tank should be replaced now.
    Because the leakage cannot be cured.
    Feb 2011
    The leaked tanked should be replaced because there is so much wastage of water.
    Feb 2011
    This is very informative to me
    Feb 2011
    According to me this is technical Error. In this Purpose Mechanic give you better advice as compare to others.
