    Dec 2008
    Default how can I change a single bathroom sink into two?
    I have a single sink in our master bathroom. By removing a towel closet next to the sink, I could expand the vanity and add a second sink. The house is built on a slab, so I do not want to rip everything up to run new lines.
    Is there a way to make a single into a double using the existing plumbing?
    1,587
    Default Re: how can I change a single bathroom sink into two?
    That should be pretty easy to do. Both sinks would have a P trap that drains into the existing waste line. No need to jack up the slab.
    Easy for a plumber and doable for the DIY homeowner.
