Thread: Corner trim
    Jun 2010
    Default Corner trim
    I'm replacing some asbestos and cement fiber siding. I need to replace a piece of the old corner trim. It is the old metal rounded type. I would like to know what I could use in its place.
    Thanks for any help
    Bkg
    Default Re: Corner trim
    If you can't find replacements at a local lumberyard or salvage, then take one to an architectural sheet metal shop (usually part of an HVAC company ) and have them duplicate them for you. With a little effort and practice you could probably make a few on your own with basic hand tools.
    1,385
    I think they still make something like that for exterior stucco corner bead; that has an inset edge/proud corner. Mason's /plasterer's supply house would be where to look. The stuff you have was heavily galvanized; the new stuff maybe less so. Paint it well.
    S_M
