    Dec 2008
    Question Rediverting Water softener discharge hose from septic
    I have recently found out that it is a bad thing to have my water softer discharge hose drain into my septic tank. I know by moving it to drain in the lawn, the salt kills pretty much everything. Any suggestions on setting up a proper discharge site for this system away from the septic? Thank you for any help provided
    Apr 2009
    Tucson
    Default Re: Rediverting Water softener discharge hose from septic
    It is not legal to run your brine on to the lawn. It has to go into your sewer. Try having you water tested and make sure you are not over doing it with the salt. Or switch to potassium.
    Jan 2009
    Taxachusetts
    136
    It must depend on your locality because in Mass everybody dumps into a rock bed outside the foundation. Salt is concretes arch enemy, I'd take a brown patch of grass over a failed septic.
    Shaun
    Apr 2009
    Tucson
    What plumbing code is Mass under?
    The UPC requires it go into the sewer.
    Doesn't seem very environmentally friendly.
