    Default Where can I find 25" air diffusers?
    WE want to replace the air diffusers in our 1970 ranch home, but can only find 24" diffusers! that leave a gap before the molding.... any ideas how to locate or order 25" diffusers? I thought this would be an easy replacement! not so...
    563
    Default Re: Where can I find 25" air diffusers?
    You might be able to install a new piece of trim & use the 24" items.
    Is this for a forced hot air system, & is it a floor register, wall register or ceiling register??
    I've seen them in the r e michel catalog listed under Lima Register, among others.
    Check your local Yellow Pages under Furnace & Duct Supply & HVAC distributors for r e michel, Sid Harveys, Simon Supply, Pameco, Johnstone Supply, etc---add a .com to these to see if they have a branch store in your area.
    The sites below have some 25" items listed.
    Hope this helps.
    http://www.acesupplyco.com/catalogs/...kReference.pdf
    http://www.jandjreg.com/PDF/Miscella...lStockList.pdf
