Thread: Sinking lawn
    Jun 2010
    Chelmsford, Mass
    10
    Default Sinking lawn
    My lawn beside my house is slowly sinking and developing sink holes. Some of these holes are 12-18 inches deep. I am constantly trying to keep them filled in but new ones develop. Coincidentally, when we have heavy rains, a large pool develops in this same spot and it takes several hours for the water to drain. Any ideas how to correct?
    7,240
    Default Re: Sinking lawn
    If the holes are recurrent in the same exact spot, then it's safe to assume that you've got a leaking drain line or some other piping that is washing the dirt away. I'd dig down and see what you can find.
    I have found irrigation line leaks, downspout, and landscape drainage to be the most likely causes of sink holes, though there could be other things as well.
    5,842
    What Spruce said. Old leech field and drainage clay tiles are commonly the cause.
    Jun 2010
    Chelmsford, Mass
    10
    Thanks to those who replied to my sinkinglawn concern. I should have been more clear - the lawn is sinking about 30-40 feet away from my house. It is not near any drain line or downspout. I am guessing it may have been a burial spot for all the trees taken down when the land was cleared to build. Any thoughts? I am also concerned with the water that pools in the same spot. Dig up and backfill with gravel or stone?
    7,240
    Once filled, how long does it take for the sink holes to reform, and have you noticed any seasonal issues, meaning that they form during the rainy season rather than the dry season.
    It's possible that it's buried organic material, but from your descriptions, the sink holes are relatively small in diameter and in several locations. If it were a buried slash pile, there would be a large area of depression rather than pinpoint sink holes.
    I would still be inclined to dig in the areas and see what's down there. If it's a damaged pipe, it can be repaired once and for all. If it's organic matter decay, you can either excavate it out or just know that you'll be adding more soil for a while until the area quits settling. I would not bother with gravel, stone or anything but native soil, because you'd only be creating another headache down the line and it's not going to alleviate the problem anyway.
