    Jun 2010
    Smile Pine walls need to be refinished
    70's ranch home-pine walls have darkened/stained over the years-
    how can i remove this stain-maybe a varnish-really don't know,
    PLEASE HELP...
    1,950
    Default Re: Pine walls need to be refinished
    Sharoncobb,
    Your pine boards may never have been stained. Nice new white pine will gradually darken and turn reddish if not stained to control oxidation. This will happen even if the pine was given coats of varnish. If the surface has oxidized, the only way to get back to the natural color of the wood is to sand it down.
    Mere varnish remover alone will not lighten it significantly. Old varnish will also age some and darken and redden. The varnish remover will help this somewhat.
    It is also possible that you do not have varnish on it, but merely shellac as a finish. If it is shellac, denatured alcohol will rapidly remove it. Try alcohol first to determine if it is shellac. If not shellac, then try varnish remover. It would be highly unusual if no clear coat, such as varnish, was put on the pine.
    In any event, it is a very labor intensive project you are attempting. You might consider painting the paneling and then giving it a wash coat of glaze to highlight it.
    Default Re: A good life raft is an essential piece
    Quote Originally Posted by zhuliang View Post
    [align=left][size=12px]A good life raft is an essential piece of life R4 card saving equipment for offshore sailors. It’s also a major capital item that creates conundrums for sailors. On the one hand, you’re never likely to need it and it has a set life span, so many would argue that the money you invest to Carbon fiber hood get a quality raft will be lost. On the other hand, should you ever find yourself in stormy weather Carbon mazda mx5 hard top stepping up into your raft, you’ll want the best one money can buy. The reality for most sailors is somewhere in between—we Needle Felt want a well-designed, equipped and constructed raft that Liquid Filter Bag represents good value for money.[/size][/align]
    Thanks you for the post.
