    Jun 2010
    Default Painting fiberglass column bases
    The paint on my out door fiberglass pillars keeps pealing.
    Last summer I tried scraping them down, wire brushing them (to scuff up - which did not work) and repainting with Zinsser Bull's Eye - they are pealing again. Any ideas on what paint to use and how to make the paint stick to the fiberglass?
    1,824
    Default Re: Painting fiberglass column bases
    MK,
    What have you been using for finsih coat paint? Normal acrylic house paint should stick directly to fiberglas. As often as I praise BIN here, it is not the greatest primer for exterior surfaces, save a few special instances such as sealing knots. Acrylic paints have the ability to bond and expand and contract with the fiberglas in the heat of the day.
