    Jun 2010
    Default exterior prep on compressed clapboards
    Nail holes and seams need to be filled with some type of expandable epoxy thats paintable and will not shrink. Anyone with any suggestions?
    1,215
    Default Re: exterior prep on compressed clapboards
    What the heck is a "compressed" clapboard?
    S_M
    Jun 2010
    S_M
    IT is like regular clapboards not wood or hardy plank it is like made of compressed fiber to look like clapboards. Its horrilble stuff knicks easy also moves with the weather thats why I'am looking for a filler that is flexible and easy to use.
    1,215
    Ahh, OK.
    Try the gel epoxy from ART:
    http://www.advancedrepair.com/archit...ural_epoxy.htm
    It sets reliably fast, and is a paintable flexible gel rather than a solid putty. It would be tough to remove any excess from a textured finished surface w/o damage. I'd say you probably have to apply before primer to avoid it flashing through the finish paint.
    We use it quite often in restoration. Downside is it's not cheap, but it should never break down or come loose.
    S_M
