Thread: table saw blade
    Jun 2010
    Question table saw blade
    I have a table saw blade that I can not get back to 90 degrees. I have tried everything I can see on the saw to get this done but, it is still about 5-10 degrees off . Any ideas??
    Default Re: table saw blade
    If it was once true and has slowly gotten out of kilter, then I'd look at dust build up in the trunnions and at the stops. The stops should be adjustable, consult your owners manual the for adjustment procedure.
