    Dec 2008
    Default Stair Tread/Riser Trim
    When the contractor installed the treads & risers he left a gap between 3/4 & 1" on both sides. Treads/risers are 1" thick (actual) and tread has a bullnose front. Length of the run from top to bottom is 15 ft. Tread is 10 1/2 inches and risers are 7 1/2 inches. There is a baseboard made of 1x10 already in place and want to seal off/cover the gap that exists. Distance from bullnose to top of baseboard varies & is between 3 1/2 & 4 inches. Distance from back of tread to baseboard is just at 10 inches. I've examined almost every possible method and can't come up with a solution. One ****** website suggested caulking & painting; but that would take over 3 tubes of caulk to fill in from the stringer to the top of the tread/front of the riser is of course 1 full inch deep. Any suggestions?
    5,987
    Default Re: Stair Tread/Riser Trim
    I'd call the contractor back.
    731
    Sounds like captured risers and treads staircase to me.
    Hey cmacres, what kind of staircase do you have?
ID:	1906   Click image for larger version.
    5,987
    Quote Originally Posted by Blue RidgeParkway View Post
    I don't see the relevance of the question. Treads and risers should have been installed by a finish carpenter and any finish carpenter that leaves a 3/4 to 1 inch gap should have to do it over. JMHO
