Thread: Mitre angles
    Jun 2008
    14
    Default Mitre angles
    I am a disabled vet and doing a lot of things isn't easy for me, especially when it comes to the technical aspect of things.
    Around my garage door (see photo) I want to put a trim around the opening. I have tried to figure out the correct angle, but for the life of me I just can't. When I tried to cut the correct angle, it looks as if one side is larger than the other.
    Is there a simple method that I can use? I suppose I will need a mitre angle finder??
    Any insight to this problem would be most appreciated.
Name:	Garage Door 003.JPG
    5,789
    Default Re: Mitre angles
    Pauley, Here's an easy way. Tack a longer than needed horizontal piece across the top of the opening, then longer than needed vertical pieces on each side. Now take a longer than needed piece for the sloped edges, align with the slope and mark both edges of all the pieces where they over lap. Make your miter cuts from mark to mark. No angle gauge needed.
    6,963
    Jack's method would be the easiest. Remember, you're only tacking these pieces to hold them long enough to mark, you'll need to get them back off to cut them.
    Jun 2008
    14
    Thanks guys. I am going to give that a try....
    Jun 2008
    14
    Sorry it took so long to reply, but I did want to say thank you! That worked perfectly!
