Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    1,134
    Default Re: Hardwood floor over concrete ( not basement)
    You are going to have movement issues at the transition from wood framing to slab. The way to prevent movement would be to have a 3/4" plywood underlayment span from framing to slab. So you are going to have to raise the whole thing by 3/4" which is going to mean transitions in height at all other entry points.
    The plywood can be attached to the slab (after moisture-proofing) with glue and con-sert (tapcon) screws.
    Casey
  2. #12
    Sep 2011
    Midwest
    37
    How about engineered over tile on concrete? My parents live in florida where everything is on a slab. They went to Home Depot and told them what they wanted, got a price and had an estimator out to the house. For this they paid about $30.00. Not until the measurer was there were they told you can't put a laminate or engineered over tile. The tile would have to be removed and the concrete sealed.
    Does that make any sense?
    Don't all the floating floors have a vapor barier?
    Waste not, want not.
    Use it up. Wear it out. Make it due, or due without.
  3. #13
    1,915
    Quote Originally Posted by Suzie02 View Post
    Thanks for the advice. I should have mentioned in the first post that most of the floor will be nailed onto a wooden subfloor.
    For instance:
    I have an 8' piece of unfinished hickory, and the last 2 feet will be
    on top concrete while the other 6' will be nailed down.
    What can I do to ensure the 2 feet on top of the concrete is secure?
    Do I allow this part to be floating or do I stick it to the concrete with an adhesive?
    Once again, thanks for the help.
    I'd use a polyurethane construction adhesive on the concrete areas and add a couple tapcon screws to each sleeper just to be certain it stays put.
    CaptTCB, I've never heard of Elastilon but I'm going to look into it. Sounds like it might solve some similar installation problems I've ran into. Thanks for the tip! Just goes to show that 30+ years in the business doesn't mean you've seen everything yet.
