This Old House Discussions
Go Back   TOH Discussions > INTERIOR > Floors & Stairs/ Hallways & Foyers
Reply
Thread Tools Display Modes
  #1
Old 11-24-2008, 01:27 PM
lbartok lbartok is offline
Junior Member
Default pull-down attic stairs
Our folding attic stairs worked perfectly for a while, then developed a problem. When pulled down, it's as if the spring has too much tension on it, so the bottom section does not rest on the floor. The spring seems to be in the proper place, resting on the top of the spring carrier. They are not cut too short, and we can "get around" the problem by hanging a bucket of water on the stairs to weigh it down. But of course we'd like to solve the problem permanently. Any ideas about what may have happened?
  #2
Old 11-24-2008, 04:50 PM
Blue RidgeParkway Blue RidgeParkway is offline
Banned
Photo Sharing and Video Hosting at Photobucket
Default Re: pull-down attic stairs
folding hinge sprung or bent or loose? truss uplift? wood dried out/shrunk? if you put a square of plywood on the floor do they reach? or maybe they're too long? maybe took on moisture and wood swelled/froze? ceiling sag? you sure they are framed correctly and still secure and not warped or out of square?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Board Jump
AMERICA'S MOST TRUSTED HOME IMPROVEMENT BRAND
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
