This Old House Discussions
Go Back   TOH Discussions > EXTERIOR > Roofing
Reply
Thread Tools Display Modes
  #1
Old 07-21-2008, 01:53 PM
belfastjim belfastjim is offline
Junior Member
Default foil radiant barrier over decking
In my yet to be built unheated workshop in Maine, I am considering a foil radiant barrier (Prodex) in lieu of felt on the sheathing. Over this would be some furring strips for ventilation and then a standing seam metal roof. I am hoping that this foil product would reduce the solar heat gain through the roof.
Would this work?
  #2
Old 07-21-2008, 04:47 PM
canuk canuk is offline
Senior Member
Photo Sharing and Video Hosting at Photobucket
Default Re: foil radiant barrier over decking
Curious .... why the furring strips for ventilation if you are using standing seam metal roofing?
If you were using asphalt shingles then I would agree with the air gap.
If you are concerned with conductive heat transfer .... you could consider laying down rigid foam sheets on the decking directly under the metal roofing.
This would provide an advantage of a continious thermo break preventing heat gain and loss.
__________________
"Time heals all things - except a leaky faucet."
- Sam Ewing
  #3
Old 07-21-2008, 09:27 PM
Junior Member
I just wanted to vent the exterior of the roof, so heat wouldn't transfer it's way through the shiplap sheathing. I am not sure of the future plans regarding insulating the building. Do you know if rigid foam would work under metal? Wouldn't there be condensation problems on the back side of the metal?
  #4
Old 07-29-2008, 01:43 AM
Ray Henry Ray Henry is offline
Junior Member
Quote:
Would this work?
A radiant barrier reflective foil will really work. Use a double sided perforated verson. This verson works both ways, it keeps the heat/cold from entering yous work space as well s keeping in heat/cold in the room. I have it installed in my home over the attic insulation and over 9 months have saved over $1,259.00 on my electric bill by reducing the kilowatts used each month by an average of 44%. I also sell and isntall the radiant barrier foil in homes and commercial buildings in south Texas where heat is more of a problem than cold. Visit my website at www.environmentalenergyimprovements.com for more background.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Board Jump
AMERICA'S MOST TRUSTED HOME IMPROVEMENT BRAND
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
