This Old House Discussions
Go Back   TOH Discussions > BATH > Design
Reply
Thread Tools Display Modes
  #1
Old 12-18-2008, 12:19 AM
shirley-il shirley-il is offline
Junior Member
Default Drilling a hole in a glass jar
I have a jar that I want to put a 5 watt bulb in. I would like to run the electric cord through a hole in the back of the jar. What kind of drill bit do I use and what is the process of drilling in glass.
  #2
Old 12-18-2008, 12:59 AM
JLMCDANIEL JLMCDANIEL is offline
Senior Member
Photo Sharing and Video Hosting at Photobucket
Send a message via Yahoo to JLMCDANIEL
Default Re: Drilling a hole in a glass jar
shirley-il,
It's a messy job. You have to grind a hole not drill it. You will need a diamond glass bit of the appropriate size, about ¼", and it is best to use a drill press. Place the bit in the drill press and run at slow speed with very little pressure. To much pressure and you will shatter the glass. You will need to keep a cooling medium, water will do, flowing on the spot you are grinding. Starting and stopping would also be a good idea. The diamond bits are usually less than $20. Patience is the key and you might want to try a couple of test jars first. wear goggles or face shield and heavy gloves. Her's a site with bits and some instructions http://www.diamond-drill-bit-and-too...-Drill-Bit.htm
By the way, if you drill through the bottom, I usually just fill the jar about ¼ full of water and drill down through the inside, Have a bucket handy.
__________________
It is one of the most beautiful compensations in life that no man can sincerely try to help another without helping himself..- Ralph Waldo Emerson
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Board Jump
AMERICA'S MOST TRUSTED HOME IMPROVEMENT BRAND
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
